Dark Rumblings
Given Taldeer could have useful information on what's down here, I wouldn't mind hearing from her while the away team explores.
Marie checks the door for any traps as they get closer to it!
[19:25] <@Ebiris> roll 1d20+71 perception
[19:25] <Penuche> Ebiris invokes Penuche's magic: < 86 > [d20=15]
We'll cover a few lines of that while Marie and Alicia's avatar get in position.
Syala heads over to Taldeer as she is healed, "Yes, do tell."
Taldeer merely begins to tell her tale, "I was visiting Coolwater Oasis to meet with a local wizard of some talent. During my time in the town, I saw signs of Shar's influence so I investigated. I ended up traveling and searching a particular sub basement - the ground is remarkably good for basements despite the aquifer, what a curious thing - when I was ambushed."
"Ambushed by what?" Alicia asks so as to learn what else might be down there beyond those twelve shadows. And also what the Sylican reinforcements going to secure the town might have to deal with.
It occurs to her that this is considerably more flashy a venture than she'd usually commit to on the prime material, but Taldeer being a close personal friend and mentor, the proximity to her old home, and the fact that it's Shar of all things compels her to push on. Shar herself is never shy about throwing her weight around after all.
"Shadows and stranger things - masked cultists, adorned with colorful feather decorations. They moved lithely, like dancers or light warriors," Taldeer says, "With magic that torn my own magic apart."
"Dispels, or do you mean like metamagic?" Alicia ask at that phrasing.
A click of her tongue, "Dispels, but violent dispels. It rended the magic apart. Vicious is the word I can think of it, like the claws of a beast."
There's a few spells that work like that, so Alicia merely hums. "What then after you were dispelled? Was it a running fight to where you prayed to me or were you knocked unconscious and woke up there?"
"I was overwhelmed," Taldeer admits, going to a nearby bench and sitting. "I knew it was Sharrans and in that moment it reminded me of you. I was hurt and reeling...I suppose I thought of you and called out to you."
"Good instincts," Antenora says, coming over and laying a hand on Taldeer's shoulder. "Not to disparage Mystra, of course."
"It worked out for the best," Alicia says. "Sending an avatar and a proxy in response to one prayer, no matter how desperate, is far out of the norm. But we are old friends, so I don't begrudge the effort." She smiles briefly and then glances at Emmaline. "Emmaline, this is Taldeer, priestess of Mystra. She oversaw my initiations into the church, and was there for me when I needed her."
Anything else you need from her before we swap back to the other side for a bit? We'll cover chatter IC later, but for now want to try and get the Oasis side done so we aren't constantly going back and forth.
Yeah that's fine, I was hoping she'd know stuff about the layout and defences but it sounds like she wouldn't so we can focus on the other side of it.
The door ahead is not trapped, Marie finds.
Marie opens the door before Alicia's avatar gets ideas about shootings beams through it.
The door is opened. It leads to stairs going up and...
Any special means of perception, you two?
Alicia just has darkvision, Marie has a full suite.
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, tremorsense 60, blindsight 60, perception +71
Marie: 515/515
Active spells: Extended superior resistance (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), extended repelling shield (CL 31), bibliotheca arcana (CL 31), extended nondetection (CL 31), sensual blessing (CL 31), extended ray deflection (CL 31)
Defences: AC 93 (touch 35), CMD 76, spell resistance 45, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), protective aura, nondetection (DC 46), ray deflection
Stat buffs/penalties: +11 shield AC, +15 insight knowledge, +25 perception
Sorcerer spell slots: 6/9/8/8/7/7/6/6/6/7/6/4/2
Avatarlicia: 582/582
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 31), ghost touch weapon (CL 31), epic mage armour (CL 31)
Defences: AC 69 (touch 32), CMD 73, spell resistance46, status immunity (polymorph, petrification, disease, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 47)
Stat buffs/penalties: +13 armour
Sorcerer spell slots: 6/13/12/11/9/9/11/8/8/8/7/6/7/4
Duskblade spell slots: 6/17/17/16/9/6
