Moving spheres
Started by Anastasia, October 24, 2018, 09:02:06 PM
Go ahead and act first, Alicia. I'll roll init if it's needed.
With a crackle of lightning Alicia crosses the distance between her and the scorpion, able to sense it well enough even if her eyes can't quite see to guide her blades as they scythe out to rend it apart nonetheless!
[19:59] <@Ebiris> roll 1d20+53 haste, channelled maximised frigid touch
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 57 > [d20=4]
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 68 > [d20=15]
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 58 > [d20=5]
[19:59] <@Ebiris> roll 1d20+48 haste, channelled maximised frigid touch
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 66 > [d20=18]
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 58 > [d20=10]
[19:59] <@Ebiris> roll 1d20+43 haste, channelled maximised frigid touch
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 51 > [d20=8]
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 57 > [d20=14]
[19:59] <@Ebiris> roll 1d20+38 haste, channelled maximised frigid touch
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 52 > [d20=14]
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 57 > [d20=19]
[19:59] <@Ebiris> roll 1d20+38 haste, channelled maximised frigid touch crit threat
[19:59] <Penuche> Ebiris invokes Penuche's magic: < 42 > [d20=4]
[20:00] <@Ebiris> roll 1d8+23+78 last is cold, assuming not evil, DC 30 fort or stunned 1 round
[20:00] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d8=6]
[20:01] <@Ebiris> roll 1d8+23+78 last is cold, assuming not evil, DC 30 fort or stunned 1 round
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 103 > [d8=2]
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 108 > [d8=7]
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d8=6]
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 109 > [d8=8]
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 102 > [d8=1]
[20:01] <@Ebiris> roll 2d8+46+156 last is cold, assuming not evil, DC 30 fort or stunned 1 round - assuming 42 crits
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 211 > [d8=3,6]
[20:01] <@Ebiris> roll 1d8+23+78 last is cold, assuming not evil, DC 30 fort or stunned 1 round - if 42 doesn't crit
Avatarlicia: 582+20/582
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 32), extended repelling shield (CL 32), recitation (CL 31), sensual blessing (CL 31)
Defences: AC 65 (touch 32), CMD 80, spell resistance 46, status immunity (polymorph, petrification, disease, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 47)
Stat buffs/penalties: +9 shield AC, +3 luck attack/saves, +4 morale attack/saves/skills, +25 competence perception
Perceptions: Darkvision 60, scent, low-light vision, blindsight 60, tremorsense 60, perception +73
Sorcerer spell slots: 6/13/12/11/9/8/10/7/7/7/7/6/7/4
Duskblade spell slots: 6/17/17/16/9/6
Marie: 589+20/589
Active spells: Extended superior resistance (CL 31), epic mage armour (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), bibliotheca arcana (CL 31), extended nondetection (CL 31), extended repelling shield (CL 31), recitation (CL 31), sensual blessing (CL 31)
Defences: AC 93 (touch 35), CMD 71, spell resistance 45, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), protective aura, nondetection (DC 46), ray deflection
Stat buffs/penalties: +15 insight knowledge, +11 shield AC, +3 luck attack/saves, +4 morale attack/saves/skills, +25 competence perception
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, blindsight 60, tremorsense 60, perception +75
Sorcerer spell slots: 6/9/10/8/9/9/8/8/8/8/8/6/5
Limited SLAs available: Meteor swarm, time stop
The scorpion is ripped asunder - and  a second later it is not. Time twists around it, the past becoming the present.
"Temporal substitution," Chrona 42 calls, "Even the most stout offense means nothing to it! It can be dispelled!"
Doing anything else this turn?
"Marie, dispel it so Syala can finish it!" Alicia calls, not seeing this as dire enough to expend a quickened superb dispelling.
Init matters now.
> roll 1d20+12 Syala
> roll 1d20 scorpion
<Penuche> Kotono invokes Penuche's magic: < 13 > [d20=1]
<Penuche> Kotono invokes Penuche's magic: < 15 > [d20=15]
Init is Marie (34) > Scorpion (15) > Syala (13)
Go Marie.
"On it!" Marie calls, first dispelling the scorpion then assailing it with a barrage of magic missiles!
Superb dispelling, how many rolls?
Marie: 589+20/589
Sorcerer spell slots: 6/8/10/8/9/9/8/8/8/8/8/5/5
[20:42] <@Ebiris> roll 4#1d20+31
[20:42] <Penuche> Ebiris invokes Penuche's magic: < 45, 35, 40, 49 >
[20:42] <@Ebiris> roll 7d4+14 quickened/twinned/repeat/entangling/fell drain magic missile (1 negative level)
[20:42] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d4=1,4,3,3,3,3,3]
[20:42] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d4=3,2,1,4,3,3,4]
Magic bursts out as the scorpion is a dozen, a hundred - and is now visible. A single one, dazeda nd reeling, battered by the missiles.
"Temporal substitution can stun you coming out of it," Chrona 42 calls, "It's vulnerable."
"Good," Syala smiles, stepping right past you, hammer in hand.
> roll 1d20 max PA, basically a 1/20 check
<Penuche> Kotono invokes Penuche's magic: < 18 > [d20=18]
> roll 1d12+87
<Penuche> Kotono invokes Penuche's magic: < 92 > [d12=5]
The stunned scorpion's head is caved in, crushed as its body tumbles down the stairs. You won!
Free act.
"At least it has a downside," Alicia says as the corpse falls away. "Well struck by the way," she adds to Syala.
"So are there any weaknesses to that spell?" Marie asks. "Any spells or types of damage that'll stick or do you just have to dispel it or outlast it?"
"Certain chronomatic spells can overcome it through harm," Chrona 42 says, "Such as Temporal Scramble and Time Lurch."
Syala flashes you a smile, "They've been so kind to set us up a training course, we should appreciate it."
Alicia takes note of those spells, deciding she'll attempt something like that on the next one. For now she continues her descent of the stairs, following the shattered invertebrate corpse.
You step down the stairs - and feel it flare along you, try to. A temporal reset, to revert you back in your body moments ago, to make you repeat what happened.
"Such magic cannot impact a deity, because they are immune to it," Chrona 42 says, "But others could be trapped in a time loop like that for a long time."
"A rather sad form of immortality," Alicia pronounces, continuing on undaunted.
"Horrifying is what it is," Syala rues, "Such power and such power to use it to extremes. Chronomancy is hardly tame magic."
At the bottom of the stairs is a painted door, decorated with images of the sky. Writing is on the base that reads, "Sky Door."
Behind the stairway is a gaping hole, leading to something of a chasm.
