A new order
Started by Anastasia, July 22, 2019, 11:42:20 PM
Okay cool, noted for when my turn comes around again.
Alicia: 914/1014
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 34), extended nondetection (CL 34), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), many moments of prescience (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), extended ray deflection (CL 34), greater visage of the deity (CL 33), extended greater anticipate teleportation (CL 34), opal protection (CL 33)
Defences: AC 116, CMD 139, spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 49), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +2 insight AC/reflex, +10 insight perception, +15 natural armour, +4 saves vs poison, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, -8 size, +17 sacred all rolls/AC, +3 morale AC
Perceptions: Darkvision, tremorsense, blindsight 3 miles, scent, arcane sight, perception +108
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/5/6/5/4/1/1
Duskblade spell slots: 6/23/21/20/10/7/7
Marie: 627/627
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33), opal protection (CL 33), Latha's sunmantle (CL 33)
Defences: AC 112 (CMD 108), spell resistance 48, energy immunity (electricity), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +15 insight knowledge, +17  sacred all rolls/AC, +3 morale AC
Perceptions: Darkvision, tremorsense, blindsight 60, scent, greater arcane sight, perception +94
Sorcerer spell slots: 6/7/10/9/8/8/8/8/7/8/6/4/0/0
Again the Tower is glowing - and this time, dozens of dark spirits erupt around Antenora.
Antenora shows no hesitation at it, "Try harder," she says in defiance, staring ahead at the tower.
Wave is up, will cover that in Seira's topic so you don't need to linger on it. You're up, Alicia.
"Here we go, Marie help me bring it down. Antenora and Latha, play defence for us," Alicia says as she compresses space ahead of her to the same distance as she saw the tower in that brief flicker during her last push forward, immediately stepping forward with Marie to hopefully get in range before things shift around again.
Seeing if that works before anything else happens.
Alicia: 914/1014
Marie: 627/627
There! A split second where it's in range ,a moment where you're right before it. A dark tower that looms high, a moment when -!
You have at least a second's chance.
Alicia swells in size to match the looming tower and sweeps her her sword low through its base while Marie drops a swarm of meteors on top of it to crush it from above!
Alicia uses a swift to go colossal+ and gets as many attacks as she can out of a full attack, Marie goes for a quickened meteor swarm on the roof, and then a twinned if she can manage it.
[18:40] <@Ebiris> roll 1d20+102 blinding speed, 10th level arcane strike, channelled maximised flux grasp
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 114 > [d20=12]
[18:41] <@Ebiris> roll 1d20+102 blinding speed, 10th level arcane strike, channelled maximised flux grasp
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 106 > [d20=4]
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 112 > [d20=10]
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 105 > [d20=3]
[18:41] <@Ebiris> roll 1d20+97 blinding speed, 10th level arcane strike, channelled maximised flux grasp
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 105 > [d20=8]
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 111 > [d20=14]
[18:41] <@Ebiris> roll 1d20+92 blinding speed, 10th level arcane strike, channelled maximised flux grasp
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 101 > [d20=9]
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 110 > [d20=18]
[18:41] <@Ebiris> roll 1d20+87 blinding speed, 10th level arcane strike, channelled maximised flux grasp
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d20=12]
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=11]
[18:41] <@Ebiris> roll 6d6+57+17+10d4+396
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 524 > [d6=5,6,6,6,2,2][d4=2,1,4,4,4,1,4,1,4,2]
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 519 > [d6=4,4,6,3,3,5][d4=2,2,3,4,1,3,2,2,4,1]
[18:42] <@Ebiris> roll 6d6+57+17+10d4+396
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 525 > [d6=6,4,2,6,6,2][d4=3,4,4,3,3,4,2,3,1,2]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 508 > [d6=3,5,1,1,2,2][d4=1,4,3,3,4,1,2,1,4,1]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 509 > [d6=2,6,1,4,1,2][d4=2,2,2,4,4,2,2,1,1,3]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 507 > [d6=5,3,1,3,1,3][d4=1,1,1,4,1,2,4,3,3,1]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 507 > [d6=5,4,1,2,1,2][d4=3,4,2,3,4,1,2,1,1,1]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 519 > [d6=6,6,6,5,2,3][d4=3,1,1,3,1,1,2,3,2,4]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 516 > [d6=1,5,5,5,2,2][d4=4,1,4,4,2,1,4,4,1,1]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 529 > [d6=2,6,5,6,3,4][d4=3,4,3,3,4,3,3,3,4,3]
[18:43] <@Ebiris> roll 15d6+15d6 fire/bludgeoning big meteor
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 114 > [d6=3,6,5,5,4,4,4,5,2,4,3,4,4,2,6,1,1,5,5,5,2,4,2,5,1,4,5,6,2,5]
[18:43] <@Ebiris> roll 5d6+5d6 fire/bludgeoning six small meteors
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d6=4,2,5,4,2,2,5,5,1,4]
[18:43] <@Ebiris> roll 15d6+15d6 fire/bludgeoning big meteor twinned
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d6=6,3,5,2,2,6,2,3,2,1,4,6,1,1,3,3,5,2,1,1,3,4,5,2,6,1,2,2,3,3]
[18:43] <@Ebiris> roll 5d6+5d6 fire/bludgeoning six small meteors twinned
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 39 > [d6=1,3,6,5,5,5,6,4,3,1]
So 180/78 for the second casting since twinned.
Alicia: 914/1014
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/5/5/5/4/0/1
Marie: 627/627
Sorcerer spell slots: 6/7/10/9/8/8/8/8/7/8/6/2/0/0
Okay. Give me d100 on all of them, there's a miss chance vs 20 involved.
[19:06] <@Ebiris> roll 10#1d100
[19:06] <Penuche> Ebiris invokes Penuche's magic: < 36, 63, 76, 19, 8, 83, 75, 29, 48, 16 >
Do I need to roll for Marie's meteor swarms?
[19:13] <@Ebiris> roll 3#1d100 big meteors
[19:13] <Penuche> Ebiris invokes Penuche's magic: < 40, 6, 86 >
[19:13] <@Ebiris> roll 18#1d100 small meteors
[19:13] <Penuche> Ebiris invokes Penuche's magic: < 19, 18, 40, 52, 48, 12, 93, 12, 61, 2, 93, 81, 96, 82, 26, 52, 76, 88 >
With your size increased and in that moment, you manage to strike the tower. Your blade cuts through shadowy stone as meteors erupt around it, a one-two combination that sunders it. The tower begins to fall, a moment of defenses overcome, before a titanic wave of pressure slams into the party.
Ref all.
[19:22] <@Ebiris> roll 1d20+76 Alicia ref
[19:22] <Penuche> Ebiris invokes Penuche's magic: < 81 > [d20=5]
[19:22] <@Ebiris> roll 1d20+72 Marie ref
[19:22] <Penuche> Ebiris invokes Penuche's magic: < 87 > [d20=15]
> roll 1d20+79 Antenora
<Penuche> Kotono invokes Penuche's magic: < 83 > [d20=4]
> roll 1d20+71 Latha improved evasion
<Penuche> Kotono invokes Penuche's magic: < 72 > [d20=1]
> roll 50d10
<Penuche> Kotono invokes Penuche's magic: < 279 > [50d10=279]
Everyone halves this the way it works out.
Init is Alicia (Supreme Init) > Marie (68) > The Chasms (67) > Shadow Hell (43) > Antenora (42) > Latha > Wave.
The blast sunders all around you, leaving the four of you reeling. Yet you survive despite pain and broken bones, wavering in the air as...
Chasms. Going to AoO. Alicia?
Antenora
HP: 389/768
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+23 (+3 morale +17 sacred, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Holy Fury 16/36 (enc) Divine Retribution 1/1 Smite Evil 7/12 Channel Energy 17/17 Lay On Hands 167/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
Spells Used: Opal Protection
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Opal Protection (CL34)
Latha
HP: 378/660
Aura: Holy Light 30ft (7d6 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil)
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+34 (+17 sacred, +14 armor, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Channel Energy 14/14 Sun Devotion 3/4
Spells Used: Heal, Mass Heal, Latha's Sunmantle, Burst of Glory, Radiant Storm
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Epic Mage Armor (CL33), Opal Protection (CL34)
Notes: Level + 7 (39) extra damage per hit vs undead during sun devotion.
Silver Fire heal on Anty, +150 HP. Latha gets made my familiar, main benefit is her base fort save will be +5 higher and she gets +17 natural armour and 2 uses of limited wish as a spell like ability. As she's my familiar I can cast personal range spells on her and cast Many Moments of Prescience, quickened. That's CL 33 and gives her a +30 insight bonus to an attack/save/AC/opposed skill check up to 4 times before being expended.
Also as my familiar we have an empathic bond so she'll feel Alicia's positive emotions which might help her?[/b]
Nope.
Alicia: 775/1014
Marie: 488/627
> roll 1d20+72 (+19 ???, +3 ???)
<Penuche> Kotono invokes Penuche's magic: < 89 > [d20=17]
Yet again all of you stand firm as the shadows strike, even now taking their bloody toll on you.
> roll 1d20+80 (+19 ???, +3 ???, +10 ???, +1 ???) touch AC.
<Penuche> Kotono invokes Penuche's magic: < 94 > [d20=14]
> roll 10d6
<Penuche> Kotono invokes Penuche's magic: < 34 > [d6=5,3,5,1,2,5,2,5,5,1]
Yet more pain as you all entire - and then Antenora's light comes, healing wrapping around you.
100 HP to Alicia and Marie from divine succor. Heal on Latha for 150 hit points of healing. Latha then uses channel energy for more healing.
> roll 19d6
<Penuche> Kotono invokes Penuche's magic: < 71 > [d6=4,2,5,2,6,3,5,2,5,5,3,5,4,4,5,3,2,5,1]
> roll 71/2
<Penuche> Kotono invokes Penuche's magic: < 35 >
> roll 71+35
<Penuche> Kotono invokes Penuche's magic: < 106 >
All allies but Latha heal 106 points of damage.
Go ahead and update HPs, more coming with a bit more Seiraposting.
Antenora
HP: 461/768
Resources: Holy Fury 14/36 (enc) Divine Retribution 1/1 Smite Evil 7/12 Channel Energy 17/17 Lay On Hands 167/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
Spells Used: Heal, Opal Protection
SLAs Used:
Typical Charging Smite Baseline: 3d8+480 plus +4/+4d6 vs fiends plus 2d6 holy plus 2d6 axiomatic 19-20 x3 (base charging smite bonus damage is 64+64=128, includes favored enemy bonus)[/i]
Latha
HP: 494/660
SLAs Used:
Done, all healed.
Alicia: 1014/1014
Marie: 627/627
