Mystran rest
Started by Anastasia, July 21, 2020, 12:51:45 PM
[18:07] <@Ebiris> roll 1d20+87 Alicia
[18:07] <Penuche> Ebiris invokes Penuche's magic: < 100 > [d20=13]
[18:07] <@Ebiris> roll 1d20+81 Marie
[18:07] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d20=9]
Alicia HP: 1284/1284
Active spells: Many moments of prescience (CL 36), Extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), death ward (CL 36), energy immunity - cold (CL 38), good hope (CL 38), Seira's Arcane Thesis (CL 38)
Defences: AC 101, CMD 163, spell resistance 51, energy immunity (negative, fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale skills, +10 armour AC, +25 competence perception, +7 insight AC/ref, +40 str, +20 con, -2 dex, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC, +2 ability checks, +5 spell DCs, +10 SR checks, +6 competence attack, +4 competence fort, +14 morale attack/damage
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/1/8/1/7/4/5/2
Many moments of prescience: 4/4
Marie HP: 830/830
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 36), extended nondetection (CL 36), greater heroism (CL 36), greater arcane sight (CL 36), epic mage armour (CL 36), sensual blessing (CL 36), repelling shield (CL 36), freedom of movement (CL 36), recitation (CL 36), true seeing (CL 36), bibliotheca arcana (CL 36), death ward (CL 36), energy immunity - cold (CL 38), superior invisibility (CL 40), good hope (CL 38)
Defences: AC 105, CMD 115, spell resistance 51, energy immunity (negative, cold, electricity, fire, sonic), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale skills, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC, +2 morale ability checks, +6 competence attack, +4 competence fort, +14 morale attack/damage
Sorcerer spell slots: 6/8/10/8/8/9/9/7/7/6/7/4/6/6/3
Many moments of prescience: 1/4
Alicia's eyes can see it. The portal out is different. It moves ever so slightly, and malicious shadows seem to be in every aspect of it, hidden and yet obvious to your superior sight.
Has it been redirected somehow? (if you can redirect it doesn't that technically make this a mobile demiplane like Aurora?)
Check to find out what's been changed with it?
Can it be changed back with a dispel or with anarch power?
You think it has been, but you'd have to study it a moment to be sure. K:P would be appropriate here.
Depending on what was done, maybe your dispels or anarch powers could do it. You'll know once you learn more with a check.
[18:42] <@Ebiris> roll 1d20+75 divine insight
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 87 > [d20=12]
The portal will take you right to Shadow now.
As to the second question possibly, depending on what exactly Shar's done to it and if you could get it away from her. You suspect yes but you also lack the ability tell from here on a glance. You'd need a deeper examination of it.
"She said die here but she clearly wants us to come to her home," Alicia says after a moment's study of the obviously altered portal.
So normally you can't plane shift out of demiplanes, right? Because they don't have astral links? But a lack of astral links never interferes with a deity's teleportation, right? So... is there anything to stop us just making our own gate out of here?
Astral links never interfere with a deity's teleportation on their home plane. That's an important distinction.
Gotcha.
Is there magic on the portal like a spell over-writing its normal properties or has it been completely changed from the ground up?
Which of the following are possible?
Alter the portal to our specifications via anarch powers/alter reality.
Create our own portal with anarch powers/alter reality.
Create an astrally linked zone with anarch powers/alter reality.
Destroy the demi-plane and eject ourselves onto... somewhere?
Go outside of Creation.
Possible but if Shar did it you may get resistance.
See above.
See above.
Possible if you did enough.
Possible if desperate enough.
"Lets try and make our own way out," Alicia says, side-stepping Shar's direct work and applying the demi-plane's morphic traits towards creating a fresh portal to its 'default' location on the ethereal plane.
"Together," Latha vows, her own will bent to it.
Charisma everyone who is trying.
Alicia quickens a limited wish to give them all +19 competence on the check ala improvisation. +2 morale from good hope.
[18:09] <@Ebiris> roll 1d20+44 Alicia charisma
[18:09] <Penuche> Ebiris invokes Penuche's magic: < 57 > [d20=13]
[18:09] <@Ebiris> roll 1d20+37 Marie charisma
[18:09] <Penuche> Ebiris invokes Penuche's magic: < 48 > [d20=11]
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/0/8/1/7/4/5/2
Marie HP: 830/830
