Shadow rondo
> roll 1d20+39
<Kobot> Kotono rolled 1d20+39 --> [ 1d20=6 ]{45}
Yet the winds can't break your own gusts, all as the demons are reeling. A moment on your own, none approaching for now as...
Antenora.
Be ready after me, I think we can push through if we force it hard!
Alicia mutely nods to Antenora. They're in a realm free to manipulate to its owners tastes, who can spawn demon lords whole cloth when needed. They'll be through when the master of this layer feels like he can't deal with them otherwise, she thinks.
> roll 1d20+90 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -20 PA, divine might)
<Kobot> Kotono rolled 1d20+90 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -20 PA, divine might) --> [ 1d20=11 ]{101}
> roll 3d8+684+2d6+2d6+10d6
<Kobot> Kotono rolled 3d8+684+2d6+2d6+10d6 --> [ 3d8=15 2d6=6 2d6=6 10d6=42 ]{753}
No need for ref saves for her.
Antenora's strike plunges through the line. As the demons recoil with the winds and power, several balors explode as Antenora goes through them. She's constantly attacking, and slowly, she opens up a path. For this moment there's a way ahead, cleared if you wish to take it.
Yet as you do, for a moment everything is wrong, purple and reversed.
Will saves, all.
Antenora
HP: 959/959
Resources: Holy Fury 38/42 (enc) Divine Retribution 1/1 Smite Evil 9/13 Channel Energy 14/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 17/25 Divine Blast 18/18
Spells Used:
SLAs Used:
[18:30] <@Ebiris> roll 1d20+77 improved m ettle
[18:30] <Kobot> Ebiris rolled 1d20+77 improved m ettle --> [ 1d20=9 ]{86}
Alicia HP: 1030/1150
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/5/3/5/5/4/0
Duskblade spell slots: 6/23/23/21/11/6/15/3
Moments of prescience left: 2
Quick-casts left: 0
> roll 1d20+76 (+10 vs alignment changing)
<Kobot> Kotono rolled 1d20+76 (+10 vs alignment changing) --> [ 1d20=8 ]{84}
It feels wrong to you, tastes wrong to you. Like a mouthful of ashes. Yet the two of you both endure it and...
Go.
By now the crystals are getting exceptionally large and deadly as they over-run and then slay more and more disarrayed demons, so Alicia is content to let them do the heavy lifting - it was a lot of magic after all, she ought to see a good return for it! The wind continues to blow back towards them, pressing demons and further limiting their movements, making them vulnerable, as she simply flies ahead and overtakes Antenora.
Full move and that's it from me. Anty has freedom of movement so the wind won't bother her.
The two of you escape - they fade away, as if they were never there at all. Another lie? Yet the path goes on.
You think that is enough?
Out of combat for the moment.
"Why are they gone? Were they not enough?" Alicia asks in turn.
The answer is a surge of crystals.
Crystals form from cracks in reality ahead. These crystals grow and connect with each other. Before you, a ram headed human forms, made entirely of a bright purple quartz or similar material. Its legs are bound together, as if crudely melted into a single one.
Nothing you can do here will avail you.
The prison for them will become the prison for you.
It's true they don't necessarily want to continue on the path laid out before them, although she hasn't yet spotted a particularly inviting alternative.
"Then why is it so different now from the last time we visited?" she asks, not immediately attacking the newly formed creature. "Are you concerned?"
You wear truth like an armor and wield glory like a sword.
Who has armed you so? What have you seen to bestow you with such glories?
"I've seen enough horrors that you can't shock me, and enough wonders that no horror will break my resolve," Alicia answers, eyes on the crystalline creature but speaking to something more abstract.
"I was not given a charge by an Incarnation, as a mortal I was free to explore Creation and make my own judgement on its worth, on my place in it. And I decided for myself that it needs protecting, that it cannot be allowed to end. Even the sunken pits of the Abyss, though a pox on Creation, I would still protect from that ultimate End."
In the distance, in the far distance, the voice of the fake celestial is heard.
Then you shall be made as I desire, as your truths shall become lies and all lies shall become truth. And when you have served your purpose, I shall consume them both!
The master of this place. In his small form, merely one of the fragments of the greater horror. It flies 600ft above and yet seems almost next to you, an expression of unhidden loathing, even as the crystalline being begins to move towards you.
Init. I know you have supreme.
> roll 1d20+14 Antenora
<Kobot> Kotono rolled 1d20+14 Antenora --> [ 1d20=17 ]{31}
> roll 1d20+11 crystal horror
<Kobot> Kotono rolled 1d20+11 crystal horror --> [ 1d20=5 ]{16}
Init is False Celestial (Supreme) > Alicia (Supreme) > Antenora (31) > Crystalline Creature (16)
Again reality feels upside down, twisted entirely. It's focused on you completely, an intense wave that seems to nearly drown you.
Will.
[17:02] <@Ebiris> roll 1d20+77 improved mettle
[17:02] <Kobot> Ebiris rolled 1d20+77 improved mettle --> [ 1d20=2 ]{79}
Something within you is ill. Wrong. You feel different, out of sync.
List 3 important facts about Alicia, please.
