Sunshine
Started by Anastasia, April 30, 2021, 01:44:19 PM
Nothing like that - unfortunately there's mostly open space around the tower.
Bit of a technical question: would Xorn movement cover the current distance? And if pushed as much power as I could into tremorsense, how far would it go?
Do you mean it covers the distance in one move? It's a few thousand feet away so no. As for tremorsense I'd have to look up the source and the distance it gives. Generally you can't push it - it is what ti is for the range of it.
Alright, then what about using Xorn Movement to get close and then Screen in like a dome?
You could try, sure.
Alyssa relays her plan to the others and begins to move closer!
I don't actually have any idea what 'close enough' is in this context.
To do what exactly? What is you want to do that requires you to get closer?
You said Xorn can't cover the movement space in one casting, so I need to get close enough that it will, so I can send the lizards to the structural weak points of the tower in groups large enough that they're able to shake it apart.
I said in one move, not one casting. You should be able to reach there in one casting with your high CL.
Oh! I meant casting, my bad. Will it last long enough to get there, shake it apart, and get back?
It would depend on your movement speeds, but on a glance, the lizards would need a second casting. You might be able to get away without on personally, though.
Alright, then let's get close enough so that the lizards can do it one casting.
Okay, describe IC what you're doing.
Alyssa casts Xorn Movement, Tremorsense, and Shrink Person on the group, then leads them to a spot close enough and uses Stone Shape to open a small space for everyone to fit in.
Once there, she'll refresh the Xorn Movement and Tremorsense on the Lizards and then direct them into position to shake the tower.
Maybe I'm missing something, but Stone Shape to fit into what?
