Wrap up (Various)
You drift in stillness, feeling water and air flow within you. You are lost in the sensations, like a mostly forgotten dream until it all ends by Bubbles shaking you shoulder. "It's been over an hour," she says, "Are you well?"
"Yes... yes," Afina blinks, reasserting her typical hold over her elements. There wasn't any of the sense of harmony or completion she felt back on Smoke. "I think there's still something I'm missing, not quite there yet." Dismissing her control temperature spell she flutters into the air, "Lets try seeing if we can find any other leads?"
Afina: 263+17/263 (-2 con), glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24)
AC 87, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear
Spell charges: 6/10/10/9/9/9/9/8/7/7/6/5
Yeah, same routine as before. I'll aid.
[19:01] <@Ebiris> roll 1d20+15 aiding
[19:01] <Kobot> Ebiris rolled 1d20+15 aiding --> [ 1d20=9 ]{24}
> roll 1d20+7 Mirajane aids
<Kobot> Kotono rolled 1d20+7 Mirajane aids --> [ 1d20=12 ]{19}
> roll 1d20+44 (+4 aiding, +6 temptation 17/20 left for encounter)
<Kobot> Kotono rolled 1d20+44 (+4 aiding, +6 temptation 17/20 left for encounter) --> [ 1d20=10 ]{54}
All of you ask around some more. There's no luck right away, but eventually you get another lead. Refuge has a great underground lake, only partly frozen and that serves as the town's water supply. You hear from various people that an old sage lives on one the ice islands that floats there, an ancient being that has studied Ice for as long as Refuge has existed.
"That sounds like a worthwhile lead to me," Afina says, seeing if they can get directions underground before venturing in that direction.
That's the easy part. There's several buildings that are just shells for paths into the ice. You go in one and go down it, stairs of carved, slippery ice. Bubbles goes gingerly, carefully - and Mirajane often reaches out at the right time, steadying her. "Careful," Mirajane murmurs, "These are meant for people used to walking on ice."
"My thanks," Bubbles murmurs.
Afina is quite glad she doesn't have to worry about that by just flying everywhere. It would do her graceful reputation no good at all to be seen slipping and sliding everywhere.
The bottom opens out to a lake, big enough that you can't see the ends of it from your position. The walls glow with an icy white light, enough to see by. A steady stream of people gather buckets of freezing cold water and head back up other sets of stairs, and guards are scattered all about.
"Seems you might have to get your furs wet after all that, Bubbles," Afina says apologetically as they reach the edge of the lake. "Unless you'd rather be carried by Mirajane?"
"Nonsense," A brief flare of magic later and she walks on the air, as if casually strolling. "You gave me this, did you forget?"
Air walking SLA used.
Mirajane
HP: 297/297
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5)
Bonuses:
Bubbles
HP: 223/223
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Air Elemental (CL-, see below), Air Walk (CL23)
Bonuses:
+1 natural armour, immune to disease and cold, +4 saves vs poison, +2 dex/con/int/wis/cha, and the following 1/day SLAs: obscuring mist, wind wall, gaseous form,, control winds, control weather, elemental swarm, and plane shift
Spell-like abilities
Always active-detect evil, discern lies, true seeing. At will-blade barrier, consecrate, dispel evil, flame strike, greater dispel magic, holy aura, holy smite, holy word, remove curse, remove disease, remove fear. 1/day-heal, vision. Caster level 23rd. The save DCs are 17 + spell level.
Mirajane casts as a 23rd level favored soul with access to the oracle domain. The save DCs are 17 + spell level.
0: AmanuensisSC, Create Water, Detect Magic, Detect Poison, Light, Mage Hand, Mending, Purify Food and Drink, Summon Holy SymbolCC
1: Conviction, Divine Favor, Ray of HopeBoED, Shield of Faith, SignSC, Twilight LuckBoED
2: Close WoundsSC, Divine InsightSC, Eagle's Splendor, Hold Person, Lesser Restoration, Lore of the GodsCC
3: Cure Serious Wounds, Fell the Greatest FoeSC, GraceSC, Prayer, RefreshmentBoED, Speak with Dead
4: Assay Spell ResistanceSC, Dimensional Anchor, Freedom of Movement, Greater Magic Weapon, Moon BoltSC, Stars of ArvandorBoED
5: Crown of FlameBoED, Greater Command, Greater Vigor, Mass Cure Light Wounds, Righteous Might, Sacred GuardianBoED
6: Antilife Shell, Bolt of GlorySC, Harm, Heal, Lucent LanceSC Stone BodySC
7: Blood to WaterSC, Fortunate FateSC, Greater Plane ShiftSC, Greater Scrying, Planar BubbleSC, Radiant AssaultSC
8: Earthquake, Greater Planar AllySC, Lion's RoarSC, Mass Death WardSC, Righteous HaloHome
9: Gate, Mass Heal, Miracle, Sublime RevelryBoED
10: Celestial ValorHome, Mass Freedom of MovementHome, Mirajane's Revelationx2Home, Summon Monster XHome
Mirajane casts as a 22nd level sentinel with access to the oracle domain. The save DCs are 17 + spell level.
1: Blessx2, Divine Favorx3
2: Lesser Restorationx5
3: Righteous Furyx5
4: Break Enchantment, Cure Serious Wounds, Freedom of Movement, Neutralize Poison
5: Cure Critical Woundsx2
Spell-Like Abilities
At will-dimension door. Caster level 22nd. The save DCs are 18 + spell level.
Bubbles casts as a 23rdlevel druid.
[6/day]0: Creater Waterx3, Cure Minor Woundsx3
[7/day]1: Cure Light Woundsx7
[7/day]2: Barkskinx7
[7/day]3: Corona of ColdSC, Neutralize Poison, Poison, Protection from Energyx3, SinkSC
[7/day]4: Control Water, Flame Strikex2, Planar Tolerancex3SC, Rusting Grasp
[6/day]5: Cloak of the SeaSC, Panaceax3SC, Wind Tunnelx2SC
[5/day]6: Antilife Shell, Extract Water Elementalx3SC, Tortoise ShellSC
[5/day]7: Animate Plants, Aura of VitalitySC, Control Weather, Creeping Doom, Heal
[5/day]8: Bombardmentx2SC, StormrageSC, Sunburst, Superior VigorHome
[4/day]9: Greater WhirlwindSC, Phantom Bearx2SC, UndermasterSC
[2/day]10: Energy Immunity, Mass Healx2
[/quote]
"I often forget about magic that's left superfluous from having wings," Afina admits unashamedly, continuing to keep pace with Bubbles and Mirajane as they start to fly or airwalk over the frigid waters. Though yes, now she thinks about it there is that, as well as the ability to turn into a free-floating cloud as options too.
"Isn't that something of a failing?" Mirajane asks quietly, "You're part air, you should be fully aware of Air's capabilities."
"You're right, I should," Afina agrees. "You never know when I might be denied the use of my wings."
Like this, all of you fly out over the lake. Amid the bitter cold, you see it's vastly large, no far shore in sight. But there's little islands dotted here and there, ice floes littering the surface of the lake. As you fly about...
Spot check, but the DC's easy enough that you won't fail it under any circumstances.
...you see one has a cave dug into it, leader deeper within. It's the first island you see with much of any sign of anything unusual.
