No longer content with mere attendance, the middle-class suburban poseurs have begun to put their hands in the air and wave them like they just don't care
Jaela: getting stuff done (Jaela)
Started by Anastasia, September 29, 2016, 05:04:15 PM
0 Members and 4 Guests are viewing this topic.
[20:59] <@Annerose> roll 1d20+60
[20:59] <Kobot> Annerose rolled 1d20+60 --> [ 1d20=9 ]{69}
[21:00] <@Annerose> roll 1d8+60
[21:00] <Kobot> Annerose rolled 1d8+60 --> [ 1d8=8 ]{68}
Your spear stabs into the dragon and you lunge forward. You pass through all of it in a few seconds, a blur of motion as you impale it from neck to tail. Hardened by the cold and no longer liquid, the dragon is torn apart and falls, before exploding violently above the ground.
Free act for the moment. You put a huge hurting on it at first and then cold + more damage did it in.
"Come on!" Jaela calls out to Mei, waving her over. Immediately after she sets for the tower while studying it....
Take 10 on K:A for 59.
The monolith falls on the ground, tumbles through several twists and then starts running towards the tower several dozen feet ahead of Jaela.
Mei catches up and in the distance you can see The Master, Dana and the efreet hurrying along. As you study the tower - oh no. Oh no. The entire thing is one arcane channel, about to discharge an absurd amount of destructive power at whereever its controller pleases. As in shatter islands and break dragons in half sort of force.
My thoughts on disrupting the spell itself/the mechanism for it/the caster's concentration with an Earthquake used on the tower? KA 10 for 59, K:Architecture and Engineering 10 for 32 if relevant.
You know that destroying the tower would stop it. An Earthquake would have a shot depending on how reinforced the tower is and how protected it is.
Incidentally, you'd estimate you're about 2000ft from the tower, give or take.
The Master and friends are about 600ft away from you.
For the second time in this series of skirmishes Jaela dismisses the monolith and becomes the wind! She dashes ahead, crossing hundreds of feet in a flash! It is not in vain, however; catching up to the others places Jaela within the extreme range of her spells, and she doesn't waste a moment forcing the ground underneath the tower and further away to dance!
Running flat out to move 600ft closer. Using a swift action to cast Earthquake to catch the tower. The center would be in a direction farther from me, in the hopes that the tower is hit unevenly and tilts in that direction if it survives outright destruction. Either way, hoping to force a concentration check from the caster.
18 rounds since spells cast.
Hit Dice 7+497/497 [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Init: +17 (Sign precast)
Detection: Blindsight 60ft, Darkvision 60ft, Listen +10, Spot +14 (+15 with Divine Insight)
Speed: 40ft (land)/120ft (flight, perfect maneuverability) [10ft enhancement from Longstrider]
Armor Class: 68 touch, 81 vs incorporeal, 88 normal, 20% miss chance. [21 from dex and cha/-21 when flat footed, 10 armor from Millennial Chainmail/Magic Vestment (Ethereal armor), light armor, 6 from natural armor, 7 shield from animated shield/Magic Vestment (5/enhancement bonus to touch AC), 2 from Foresight, 3 luck from Recitation, 20 force from epic mage armor, 5 sacred with Shield of Warding, 1 from Haste, 1 morale from Mei]
BAB/CMB/CMD: +24/+33/76
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5): +60/+60/+55/+50/+45, 2d8+60+8d6, x3/20, 15ft [silver+good+anarchic+epic]
Full Attack (Gae Dioltas, GMW, Haste, HW, K:D +5, charge): +60,  4d8+272, x3/20, 15ft [+74 charging smite, 4d8+272+120, silver+good+epic]
*Full Attack (Gae Trocaire, GMW, Haste, HW): +42/+42/+37/+32/+27, 1d8+31+1d6 non-lethal, x3/20, 10ft [+2 damage vs DR/silver, +1d6 vs incorporeal/gauntlets, +2d6 from celestial brilliance, +14 Divine Might, +3 luck from Recitation; piercing/bludgeoning/slashing/silver/bypasses any DR next round after successful hit for 10 rounds]
Ray Attack: +45
[+2 damage Good Hope counted, +3 Recitation counted, +4 Celestial Valor counted, +4 Greater Heroism counted, +5 attack/+8 damage Holy Warrior not counted]
Resistances and Immunities: Fire Resistance 10, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 10, Damage Reduction 20/Epic and Evil and Cold Iron, Spell Resistance 34 (43 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Foresight/not surprised or flat-footed.
Saves: Fort +65, Ref +58, Will +58 [Counted: Conviction +5 to each save, Foresight +2 to Ref, Haste +1 to Ref, Shield of Warding +5 to Ref, Recitation +3 to each save, +4 sacred Fort and Will/Celestial Valor; Not counted: Good Hope +2 to each save, Greater Heroism +4 to each save]
Precast/Bead of Karma: Energy Immunity/Cold CL30, Permanency/Greater Blindsight CL30 [Blindsight for 60ft], Permanency/Mantle of Good CL31, Permanency/Prestidigitation CL30, Extended Lore of the Gods CL30 (10hr duration), Righteous Halo CL30, Longstrider CL25, Moment of Prescience CL25
Cast: Energy Immunity/Fire CL26, Epic Mage Armor CL24, Fortunate Fate CL24, Conviction CL24, Sign CL24, Divine Insight CL24, Spell Turning CL24, Heroes's Feast CL20, Control Water CL18, Mind Blank CL17, Planar Tolerance CL7, GMW CL26/Gae Bolg, GMW CL26/Gae Trocaire, GMW CL26/Gae Dioltas, MV CL27/Millenial Armor, MV CL27/Shield, Foresight CL23, Good Hope CL26, Greater Heroism CL26, Haste CL21, Recitation CL26, Shield of Warding CL26, Fell the Greatest Foe CL26, Celestial Valor CL26, Divine Power CL23.
Favored Soul slots left, 01-11: 3/0/0/0/0/0/0/0/1/0/1
CL 26 Favored Soul, CL 21 Divine Crusader [+2CL untyped War domain, +1CL competence Force, +1CL untyped Protection domain, +1CL untyped Abjuration]
Spell/SLA DC: 24 + spell level
Bolt of Glory channeled into Gae Bolg.
6/17 Turning left
-2 smite
-404 LoH (2 left)
Okay, while this won't bring down the tower, it may well disrupt what's happening. There's no rule that smoothly covers this, so I'm going to call it an opposed caster level check. If there's a caster or user directly involved, his concentration isn't relevant to what's going on.
Go ahead and make one for earthquake, Jaela. It's basically two spells squaring off in the most elemental way possible.
08:52 <Tohsaka> roll 1d20+26 CL
08:52 <Kobot> Tohsaka rolled 1d20+26 CL --> [ 1d20=1 ]{27}
> roll 1d20+29 yeah, a 1 was not needed there
<Kobot> Sunshine_Ko rolled 1d20+29 yeah, a 1 was not needed there --> [ 1d20=9 ]{38}
More in the morning since it's 2 AM, but the roll did not go Jaela's way.
Magic meets magic as the ground beneath the tower shudders. Yet the tower is rock solid, beams of dark red light flying from it - including one at you and another at Mei, as well as at your elemental. More fly at Dana and friends further ahead.
> roll 1d20+34 (-6 circumstance due to earthquake) vs Jaela's touch AC of 68
<Kobot> Sunshine_Ko rolled 1d20+34 (-6 circumstance due to earthquake) vs Jaela's touch AC of 68 --> [ 1d20=12 ]{46}
> roll 1d20+34 (-6 circumstance due to earthquake) vs Mei's touch AC of 38
<Kobot> Sunshine_Ko rolled 1d20+34 (-6 circumstance due to earthquake) vs Mei's touch AC of 38 --> [ 1d20=13 ]{47}
> roll 1d20+34 (-6 circumstance due to earthquake) vs elemental's touch AC of not anywhere near that
<Kobot> Sunshine_Ko rolled 1d20+34 (-6 circumstance due to earthquake) vs elemental's touch AC of not anywhere near that --> [ 1d20=8 ]{42}
> roll 1d20+34 (-6 circumstance due to earthquake) vs Dana's touch AC of 64
<Kobot> Sunshine_Ko rolled 1d20+34 (-6 circumstance due to earthquake) vs Dana's touch AC of 64 --> [ 1d20=17 ]{51}
> roll 1d20+34 (-6 circumstance due to earthquake) vs Master's touch AC of 70
<Kobot> Sunshine_Ko rolled 1d20+34 (-6 circumstance due to earthquake) vs Master's touch AC of 70 --> [ 1d20=18 ]{52}
> roll 1d20+34 (-6 circumstance due to earthquake) vs efreet almost forgot
<Kobot> Sunshine_Ko rolled 1d20+34 (-6 circumstance due to earthquake) vs efreet almost forgot --> [ 1d20=4 ]{38}
> roll 20d10 Mei
<Kobot> Sunshine_Ko rolled 20d10 Mei --> [ 20d10=107 ]{107}
> roll 20d10 Elemental
<Kobot> Sunshine_Ko rolled 20d10 Elemental --> [ 20d10=119 ]{119}
> roll 20d10 efreet
<Kobot> Sunshine_Ko rolled 20d10 --> [ 20d10=118 ]{118}
You just catch up to Dana and the others as the beams come forth. Dana grunts and brings her shield up, parrying the blast. The Master sways like the wind, not missing a step as he evades the beam. The efreet barely has time to react before he's hit, reduced to dust. You don't see what happens to the beam fired back at Mei or the elemental, as you have to stop and dodge the blast at you. The Triune's protection comes through, as the beam sputters out before it touches you.
"Damn," Dana says, "Fuckers aren't even trying to send creatures at us anymore, just blast us from fucking afar."
Go.
[spoiler]
Dana
HP: 210/324 fast healing 2
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Energy Immunity (Fire) (CL26), Good Hope (CL26),
Haste (CL21), Recitation (CL26), Celestial Valor (CL26), Divine Protection (CL12), Steadfast Perception (CL23)
Bonuses: +1 morale attack rolls and Will saves, immunity to poison and disease, +2 morale to attack rolls, weapon damage rolls, skill checks, ability checks and saving throws, +1 attack rolls, +1 ref saves, +1 full attack, movement speed bonus, +2 luck to saves, +8 sacred vs negative emotions, +4 sacred attacks, weapon damage rolls, saves and armor class, weapons count as holy (doesn't stack), +1 morale armor class, immunity to figments and glamers, +6 enhancement to spot checks.
Negative Conditions:
Resources Used: 137/262 Power Points
The Master
HP: 272+20/304
Bonuses: +1 morale attack rolls and Will saves, immunity to poison and disease, +2 morale to attack rolls, weapon damage rolls, skill checks, ability checks and saving throws, +1 attack rolls, +1 ref saves, +1 full attack, movement speed bonus, +2 luck to saves, +8 sacred vs negative emotions, +4 sacred attacks, weapon damage rolls, saves and armor class, weapons count as holy (doesn't stack), +1 morale armor class.
Resources Used: 14 stunning fists
Mei
HP: 327/457
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Energy Immunity (Fire) (CL26), Good Hope (CL26),
Resources Used: 1 smite, 1 voice of the triune
Spell-like abilities
1/day-daylight. Caster level 22nd. The save DCs are 16 + spell level.
Dana manifests as a 22nd level psychic warrior. The save DCs are 17 + power level.
Power points: 262
[1 pp]1: Defensive PrecognitionA, Offensive PrescienceA, VigorA.
[3 pp]2: Body AdjustmentA, Dimension SwapA, Strength of My EnemyA.
[5 pp]3: Breath BarrierA, Dimension SlideA, Greater Concealing Amorpha.
[7 pp]4: Energy AdaptationA, Psionic Freedom of Movement, Steadfast Perception.
[9 pp]5: Empower Weapon, Oak BodyA, Perfect RiposteA
[11 pp]6: Breath of the Black DragonA, Form of DoomA, Inconstant LocationA, Personal Mind Blank, Stygian TouchA
[13 pp]7: Dana's AdjustmentA, Dana's CounterA
A - Power can be augmented.
Dana manifests as a 1st level ardent with access to the pain + suffering and physical power mantles. The save DCs are 17 + spell level.
[1 pp]1: Adrenaline BoostA, DisableA
Mei casts as a 12th level paladin. Her spell DCs are 21 + spell level. Her spell themes are protection and boosting.
Check spells per day.
[4/day]1: Divine Favor, True Strike, Lesser Restoration
[4/day]2: Divine Protectionx3SC
[4/day]3: Righteous Furyx4SC
SC - Spell Compendium.
Mei uses invocations as a 23rd level warlock.
Least: All Seeing Eyes, Eldritch Glaive, Otherworldly Whispers.
Lesser: Baneful Blast(Evil Outsiders), Celestial Flight, Eldritch Chain, Spirit Blast, Wall of Light.
Greater: Eldritch Cone, Heavenly Endurance, Penetrating Blast, Vitriolic Blast.
Holy: Caster's Lament, Eladrin Form, Impenetrable Barrier, Steal Summoning.
Epic: -
[/quote]
[/quote]
[/quote]
"Run!"
Running another 600ft. Elemental is gone.
All of you, save Mei in the back, run.
You're a mere 800ft away now. The tower looms large as more beams come, the earthquake coming to a stop.
> roll 1d20+40 vs Jaela's touch AC of 68
<Kobot> Sunshine_Ko rolled 1d20+40 vs Jaela's touch AC of 68 --> [ 1d20=3 ]{43}
> roll 1d20+40 vs Mei's touch AC of 38, needs a 1
<Kobot> Sunshine_Ko rolled 1d20+40 vs Mei's touch AC of 38, needs a 1 --> [ 1d20=6 ]{46}
> roll 1d20+40 vs Dana's touch AC of 64
<Kobot> Sunshine_Ko rolled 1d20+40 vs Dana's touch AC of 64 --> [ 1d20=12 ]{52}
> roll 1d20+40 vs Master's touch AC of 70
<Kobot> Sunshine_Ko rolled 1d20+40 vs Master's touch AC of 70 --> [ 1d20=4 ]{44}
> roll 20d10 Mei again owwies
<Kobot> Sunshine_Ko rolled 20d10 Mei again owwies --> [ 20d10=120 ]{120}
Again you dodge. Dana and the Master are too strong and fast, you're protected by the Triune and your magic. You hear a wordless cry of, "Aaaaaaaaah!" The voice is sweet but pained - Mei's voice, you know it from when she speaks the Words of the Triune.
Go.
[spoiler]
Dana
The Master
HP: 272+20/304
Mei
HP: 207/457
Power points: 262
Epic: -
[/quote]
[/quote]
[/quote]
[/quote]
"Mei, get closer and shield with the wall!" Jaela yells back, dashing closer still.
My third run of 600ft should bring me within ~200ft of the tower, due to the original distance of around 2,000ft. Can you please note where everyone else is from the tower by the time the next round starts for me, whether I can see any entrances to the tower and if they're open/closed, and whether my earlier KA and K:engineering and architecture results also gave me an idea about the best place to hit it to destabilize it?
