A Faraway Victory
Started by Anastasia, July 24, 2018, 04:18:50 PM
From Superb Dispelling:
This spell functions as greater dispel magic, with a maximum dispel check cap of +40. It can automatically destroy an antimagic field, as well as affect anything a magic disjunction can. This spell is often preferred over Magic Disjunction due to its tighter radius of effect.
And from Mage's Disjunction:
Even artifacts are subject to disjunction, though there is only a 1% chance per caster level of actually affecting such powerful items.
Mage's Disjunction =/= Magic Disjunction. The relevant part is quoted from the Spell Collection.
QuoteYou also have a 1% chance per caster level of destroying an antimagic field. If the antimagic field survives the disjunction, no items within it are dispelled.
Artifacts and divinities are unaffected by mortal magic such as this.
Under the circumstances, just go ahead and redo Marie's turn.
Does that mean deities are straight up immune to being dispelled?
Anyway sure fine, retcon away.
"I'm dropping my teleport block, put it in your portable hole!" Marie suggests as the interdiction against teleportation and summoning goes away.
Standard to dismiss teleport block and she's done.
Alicia: 1137/1140
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 32), extended greater anticipate teleportation (CL 32), sensual blessing (CL 31), epic mage armour (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 32), dance of the unicorn (CL 32), spell turning (CL 32), greater visage of the deity (CL 31), foresight (CL 31), vision of the omniscient eye (CL 31), extended repelling shield (CL 32), extended ray deflection (CL 32), divine protection (CL 31), energy immunity (electricity) (CL 31), haste (CL 31)
Defences: AC 94 (touch 29), CMD 110, spell resistance 46, energy immunity (fire, cold, electricity), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting), freedom of movement, nondetection (DC 47)
Stat buffs/penalties: +25 competence perception, +12 armour, +3 morale damage, +3 luck attack/saves, +34 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +1 natural armour, -7 size, +2 insight AC/reflex, +10 insight perception, +9 shield AC, +4 morale attack/saves/skills, +1 morale AC, +1 attack/AC/reflex
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +84
Sorcerer spell slots: 6/6/9/9/8/8/6/7/7/7/6/5/2/1
Duskblade spell slots: 6/12/12/10/10/6
Marie: 909/912
Active spells: Extended superior resistance (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 31), extended repelling shield (CL 31), bibliotheca arcana (CL 31), sensual blessing (CL 31), extended ray deflection (CL 31), extended nondetection (CL 31), divine protection (CL 31), power of the huntress (CL 31), haste (CL 31), many moments of prescience (CL 31)
Defences: AC 100 (touch 23), CMD 72, spell resistance 43, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), status immunity (protection, death effects, energy drain) protective aura, ray deflection, nondetection (DC 46), improved evasion
Stat buffs/penalties: +4 deflection AC vs evil, +3 morale damage, +11 shield AC, +15 insight knowledge, +25 competence perception, +3 luck attack/saves, +4 morale attack/saves/skills, +16 natural armour, +1 morale AC, +10 enhancement strength/constitution, +4 enhancement dexterity, +3 enhancement natural armour, +20 competence stealth, +6 initiative, +1 attack/AC/reflex
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, blindsight 60, tremorsense 60, perception +70
Sorcerer spell slots: 6/4/8/8/5/8/6/6/6/7/6/2/1
4 moments of prescience left
No. I simply changed a bit on mage's disjunction years and years ago, didn't want to rewrite the entire spell, so I just flipped some language in a similar thing (antimagic field, I think). The basic point was simply to not allow artifacts to be nuked by non epic magic and leave that a question for epic magic.
I'll probably rewrite that as a todo, it's oooold and hasn't ever come up until now
The teleport block falls as...
Init is Marie (36) > Syala (30) > Alicia (24) > Statue Man (17) > Antenora (16)
Syala in the next post, I need a few to figure out her turn. Feel free to react if you want to, otherwise I'll post again shortly.
Well superb dispelling is epic magic, so I feel that's relevant now! No reaction though, Alicia will follow Marie's advice unless Syala does something even better.
I'll put it as a todo then to figure out.
Syala looks on at the slaads, and with a casual gesture, "Go away," she says, as a raging tsunami appears, a vast tidal wave that rises up and sweeps over the slaad, then repeats with a second wave.
Using the free twin from Blessing of the Twelve.
> roll 20d6
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=70 ]{70}
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=75 ]{75}
> roll 1d20+20
> roll 1d20+20
<Rei-chan> Kotono rolled : 1d20+20 --> [ 1d20=7 ]{27}
<Rei-chan> Kotono rolled : 1d20+20 --> [ 1d20=9 ]{29}
The tidal waves sweep the slaad away, dragging them along and crushing them under a tsunami of raging waters. As they fall...
Alicia. Slaad down here are neutralized for th emoment.
No pain feedback from that?
Alicia casts time stop!
[18:04] <@Ebiris> roll 1d4+1 time stop
[18:04] <Rei-chan> Ebiris rolled : 1d4+1 time stop --> [ 1d4=3 ]{4}
Anyone but Marie got spell stowaway nearby?
Alicia: 1137/1140
Sorcerer spell slots: 6/6/9/9/8/8/6/7/7/6/6/5/2/1
Marie: 909/912
Alicia feels the sense of beign crushed, of drowning abruptly as...
No, just the two of you. Go for it.
Walking over to the statue, Alicia takes out her portable hole and unfurls it, picking the gaudy but admittedly well made piece of art and placing it inside the extradimensional space before folding it up neatly again.
Does that bring her senses back to normal?
That's probably like 2 rounds of action there.
Your senses immediately snap back to normal.
"Oooh, you miss it already don't you?" Marie says, holding position by the dragon-corpses.
"Yes, but it's for the best," Alicia says as she performs the same addiction-curing magic Syala used on Jessica earlier on the two of them. "Put your dimensional block back up, I don't want more complications showing up."
"Got it!" Marie grins and casts her spell once more before time restarts.
"Free to engage now, I've got the artifact contained!" Alicia calls to Antenora and Syala.
Alicia: 1137/1140
Marie: 909/912
Active spells: Extended superior resistance (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 31), extended repelling shield (CL 31), bibliotheca arcana (CL 31), sensual blessing (CL 31), extended ray deflection (CL 31), extended nondetection (CL 31), divine protection (CL 31), power of the huntress (CL 31), haste (CL 31), many moments of prescience (CL 31), extended Jaela's teleport block (CL 31)
Sorcerer spell slots: 6/4/8/8/5/8/6/6/6/7/5/2/1
Init is Marie (36) > Syala (30) > Alicia (24) > Slaad (17) > Antenora (16)
The slaad above are stymied but from below? Dozens of slaad-hands begin to rip through the floor, slowly tearing it apart, forcing their way in. Above the slaad renew their assault, trying to get past the deific walls of force.
At the same time, the leftmost wall suddenly buckles violently, the roar of some great beast heard as...
K:A, +5 circumstance bonus.
[18:37] <@Ebiris> roll 1d20+49+5 Alicia arcana
[18:37] <Rei-chan> Ebiris rolled : 1d20+49+5 Alicia arcana --> [ 1d20=8 ]{62}
[18:37] <@Ebiris> roll 1d20+60+5 Marie arcana
[18:37] <Rei-chan> Ebiris rolled : 1d20+60+5 Marie arcana --> [ 1d20=9 ]{74}
Oh, that's one you know from a past battle. That's a tarrasque's roar, that's all.
Wait, WHAT?! A tarrasque?! What? WHY?!
Antenora's head whips over, "TARRASQUE?!" she whirls, scowling, "Chourst!"
I call him Red! HAVE FUN PLAYING! I made some chewy adjustments, too!
Antenora floats above the floor, turning to the wall and braced, ready to meet a charge if need be.
Marie, go. You all can make a followup K:P check if you like.
Init is Marie (36) > Syala (30) > Alicia (24) > Slaad = TARRASQUE?! (17) > Antenora (16)
"Hey, we're a lot tougher than we were last time right?" Marie says to encourage everyone, raising her arm as another mass of missiles appears out of the air around her, dozens and then hundreds and then thousands, all perfectly shooting off into the distance and around corners or obstacles to impact onto anything that isn't her or Alicia or Syala or Antenora! She hums an inspirational ditty all the while.
[18:49] <@Ebiris> roll 1d20+33 amazing barrage SR
[18:49] <Rei-chan> Ebiris rolled : 1d20+33 amazing barrage SR --> [ 1d20=15 ]{48}
[18:49] <@Ebiris> roll 1d3+31
[18:49] <Rei-chan> Ebiris rolled : 1d3+31 --> [ 1d3=2 ]{33}
[18:49] <@Ebiris> roll 1d20+49 Alicia planes
[18:49] <Rei-chan> Ebiris rolled : 1d20+49 Alicia planes --> [ 1d20=10 ]{59}
[18:49] <@Ebiris> roll 1d20+60 Marie planes
[18:49] <Rei-chan> Ebiris rolled : 1d20+60 Marie planes --> [ 1d20=1 ]{61}
Also using Inspire Heroics as a free action. +4 dodge AC for all.
Alicia: 1137/1140
Defences: AC 98 (touch 33), CMD 114, spell resistance 46, energy immunity (fire, cold, electricity), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting), freedom of movement, nondetection (DC 47)
Marie: 909/912
Defences: AC 104 (touch 27), CMD 76, spell resistance 43, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), status immunity (protection, death effects, energy drain) protective aura, ray deflection, nondetection (DC 46), improved evasion
Sorcerer spell slots: 6/4/8/8/5/8/6/6/6/7/5/2/0
