A Faraway Victory
Started by Anastasia, July 24, 2018, 04:18:50 PM
Marie wasn't blind to those flashes of force blocking Antenora's shield, so as tempting as these slaad are to her amazing barrage, she helps her wife out first by unbinding that force!
Using Unbind Force since it specifies it can take down effects as well as spells.
At 5th level, an argent savant learns how to unweave a force spell or effect and liberate its magical energy. As a standard action, she can attempt to dispel a single force spell or effect within 60 feet (even those normally immune to dispel magic, such as wall of force). If she succeeds on a caster level check (DC 11 + opposing caster's level).
[14:54] <@Ebiris> roll 1d20+32 unbind force
[14:54] <Rei-chan> Ebiris rolled : 1d20+32 unbind force --> [ 1d20=12 ]{44}
Swift to use pending this.
A ripple around the statue, force being unwoven around it. It dissolves into strands of glowing radiance that fades under Marie's newfound magic.
"That should be easier now!" Marie calls over, moving towards the dragon corpses so she can get around them and find that artifact. But for now she gestures up at the meteorite and covers one side of it in a whirling sleet storm to confuse and slow any slaad emerging from it.
Quickened sleet storm, 40 foot radius of blinding snow and slippery ice.
Alicia: 1137/1140
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 32), extended greater anticipate teleportation (CL 32), sensual blessing (CL 31), epic mage armour (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 32), dance of the unicorn (CL 32), spell turning (CL 32), greater visage of the deity (CL 31), foresight (CL 31), vision of the omniscient eye (CL 31), extended repelling shield (CL 32), extended ray deflection (CL 32), divine protection (CL 31), energy immunity (electricity) (CL 31), haste (CL 31)
Defences: AC 94 (touch 29), CMD 110, spell resistance 46, energy immunity (fire, cold, electricity), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting), freedom of movement, nondetection (DC 47)
Stat buffs/penalties: +25 competence perception, +12 armour, +3 morale damage, +3 luck attack/saves, +34 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +1 natural armour, -7 size, +2 insight AC/reflex, +10 insight perception, +9 shield AC, +4 morale attack/saves/skills, +1 morale AC, +1 attack/AC/reflex
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +84
Sorcerer spell slots: 6/6/9/9/8/8/6/8/7/7/6/5/3/1
Duskblade spell slots: 6/12/12/10/10/6
Marie: 909/912
Active spells: Extended superior resistance (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 31), extended repelling shield (CL 31), bibliotheca arcana (CL 31), sensual blessing (CL 31), extended ray deflection (CL 31), extended nondetection (CL 31), divine protection (CL 31), power of the huntress (CL 31), haste (CL 31), many moments of prescience (CL 31)
Defences: AC 100 (touch 23), CMD 72, spell resistance 43, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), status immunity (protection, death effects, energy drain) protective aura, ray deflection, nondetection (DC 46), improved evasion
Stat buffs/penalties: +4 deflection AC vs evil, +3 morale damage, +11 shield AC, +15 insight knowledge, +25 competence perception, +3 luck attack/saves, +4 morale attack/saves/skills, +16 natural armour, +1 morale AC, +10 enhancement strength/constitution, +4 enhancement dexterity, +3 enhancement natural armour, +20 competence stealth, +6 initiative, +1 attack/AC/reflex
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, blindsight 60, tremorsense 60, perception +70
Sorcerer spell slots: 6/4/8/8/5/8/6/6/6/7/6/2/2
4 moments of prescience left
Movement speed for the dread Marie?
70 currently while hasted, so I guess she can get partially around them.
Init is Marie (36) > Syala (30) > Alicia (24) > Statue Man (17) > Antenora (16)
Syala takes 10 on K:P.
"Chourst," Syala says aloud, scowling.
What do you want, Lord of Randomness?
Chance to react pending Syala's action, which will depend on the answer she gets here.
Alicia glares up at the meteorite. "This isn't a game. Leave or be considered an enemy!"
Can I sense another deity present in the meteorite?
You cannot - but as Chourst is on his homefield, he could easily be hiding or simply talking from afar. It's not like he can't ignore the anti teleportation measures here since it's on LImbo.
That's fine, carry on with Syala, I wasn't holding up for an answer or anything just curious. There are annoying slaad present either way.
Syala gestures, the wall of force expanding rapidly, connecting to another, covering more of the roof.
FUN! FOOD! FRIENDS! FORKS! FAREWELLS! FIRE! FRISKINESS! FULCRUMS!
Alicia, you're up.
With two giant steps Alicia crosses over to join Antenora, reaching down towards the statue and coating it in deadly acid!
Flux grasp
[17:50] <@Ebiris> roll 1d20+63 melee touch
[17:50] <Rei-chan> Ebiris rolled : 1d20+63 melee touch --> [ 1d20=16 ]{79}
[17:50] <@Ebiris> roll 31d12
[17:50] <Rei-chan> Ebiris rolled : 31d12 --> [ 31d12=202 ]{202}
DC 37 fort or loses 10 to both armour and natural armour bonuses. Affects objects.
Alicia: 1137/1140
Sorcerer spell slots: 6/6/9/9/8/8/6/8/7/7/6/5/2/1
Marie: 909/912
Your hand touches the statue's chest, acid rising over it. In an instant it's half melting, acid eating away at it, making it sag like a wax statue left out in the sun. It seems almost runny now, melting as...
Anything else this turn?
Half melted and crumbling, the statue man emits more poison - to as little effect as last time.
Meanwhile slaad rain down, more and more stopped by the twin walls of force. They claw it, pound on it, throw magic at it - but they hold. The ones that are left charge in, coming at the party, coming closer and closer.
They're at the far end and time is needed to get around, too. Antenora.
> roll 1d20+59 (+7 various, +1 blinding speed)
<Rei-chan> Kotono rolled : 1d20+59 (+7 various, +1 blinding speed) --> [ 1d20=9 ]{68}
> roll 1d20+59 (+7 various, +1 blinding speed) haste bonus attack
<Rei-chan> Kotono rolled : 1d20+59 (+7 various, +1 blinding speed) haste bonus attack --> [ 1d20=17 ]{76}
> roll 1d20+54 (+7 various, +1 blinding speed)
<Rei-chan> Kotono rolled : 1d20+54 (+7 various, +1 blinding speed) --> [ 1d20=14 ]{68}
> roll 1d20+49 (+7 various, +1 blinding speed)
<Rei-chan> Kotono rolled : 1d20+49 (+7 various, +1 blinding speed) --> [ 1d20=5 ]{54}
> roll 1d20+44 (+7 various, +1 blinding speed)
<Rei-chan> Kotono rolled : 1d20+44 (+7 various, +1 blinding speed) --> [ 1d20=19 ]{63}
> roll 1d8+30
> roll 1d8+30
> roll 1d8+30
> roll 1d8+30
<Rei-chan> Kotono rolled : 1d8+30 --> [ 1d8=2 ]{32}
> roll 1d8+30
<Rei-chan> Kotono rolled : 1d8+30 --> [ 1d8=8 ]{38}
<Rei-chan> Kotono rolled : 1d8+30 --> [ 1d8=1 ]{31}
<Rei-chan> Kotono rolled : 1d8+30 --> [ 1d8=5 ]{35}
Antenora stabs into the statue again and again. Now it actually works, the statue man being skewered. No blood, only melting stone falling away as it crumbles, acid and wounds too much as it collapses into a heap of acid-scarred stone and rubble. Got it!
Marie.
Marie moves the rest of the way around the dragons so she can lay her greedy eyes on that artifact. But also... "You were warned, so time to taste something amazing!" she calls out as she's obscured from sight for several seconds by the sheer volume of glowing bright purple force orbs that swirl around her body and careen off in all directions, zipping through and around and outside the fortress, far more of them however spiralling up into the sky and surrounding the meteorite, peppering creatures on its surface and  zig-zagging their way through the various craters and caverns to penetrate its interior, a single missile inexorably seeking out every creature no matter how well hidden and delivering eladrin vengeance!
[18:33] <@Ebiris> roll 1d20+34 amazing barrage SR
[18:33] <Rei-chan> Ebiris rolled : 1d20+34 amazing barrage SR --> [ 1d20=8 ]{42}
[18:33] <@Ebiris> roll 1d3+31
[18:33] <Rei-chan> Ebiris rolled : 1d3+31 --> [ 1d3=3 ]{34}
She's done, no swift this turn.
Alicia: 1137/1140
Marie: 909/912
Sorcerer spell slots: 6/4/8/8/5/8/6/6/6/7/6/2/1
