The hunt for companionship (Calleigh)
Started by Anastasia, August 30, 2016, 03:44:42 PM
Hanna and Simmer join you. They listen to your story, "Oh, so a breakout?" Simmer says, "I can set them all on fire, will that do?"
"Explosions are also good!" Calleigh says, nodding.
"Then we have this," Simmer says, "Easy as can be. We go, I set all the demons on fire, we come back with treasure."
"And treasure, for more fire," Simmer says, nodding along, "My emergency supply closet of fire needs more fire."
"Of course I do. It's in a bag of holding, but it's a lot of fire in there. Lots of useful fire." Simmer nods, "You can never have enough fire."
Calleigh nod-nods. "That's a good point. Are we ready!?"
Agreement all around.
How are you going to approach this, Tryll?
Scouting, infiltration, violence
Specifically we'll scout out the location, determine enemy contingent, attempt to turn them against each other with Dominate, and then get the dudes out. Violence if required (likely)
Okay, where exactly are you plane shifting to?
Moonlight
HP: 414+14/414
Bonuses: +1 morale attack and Will saves
Hanna
HP: 354/354
Simmer
HP: 333/333
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL23), Heroes Feast (CL20), Superior Resistance (CL23)
Always active: Detect Evil, Detect Snares and Pits, Discern Lies, See Invisibility, True Seeing.
Spell-like abilities
At will-continual flame, dispel magic, holy smite, invisibility (self only), lesser restoration, remove curse, remove disease, remove fear, speak with dead; 3/day-blade barrier, flame strike, power word stun, waves of fatigue; 1/day-earthquake, greater restoration, mass charm monster, waves of exhaustion. Caster level 22nd. The save DCs are 16 + spell level.
Hanna casts as a 23rd level cleric with access to the War and Wrath(BoED) domains. The save DCs are 20 + spell level. Her spell themes are holy magic, healing and extended buffs. Her metamagic options are Extend Spell (+1) and Consecrate Spell (+1).
[6/day]0: Create Waterx6.
[8+1/day]1: (Doom), Divine Favor, Ray of HopeBoEDx2, Shield of Faithx3, Twilight Luckx2BoED
[8+1/day]2: (Spiritual Weapon), Close Woundsx2SC, Eagle's Splendorx2, Extended Divine Favorx2, Hold Personx2
[7+1/day]3: (AfflictionBoED), Cure Serious Woundsx2, Prayerx2, RefreshmentBoEDx2, Telepathy TapBoED. S(1d3 str).
[7+1/day]4: (Radiant ShieldBoED), Blood of the MartyrBoED, Dimensional Anchorx2, Extended Prayer, Freedom of Movementx2, Stars of ArvandorBoED.
[7+1/day]5: (Righteous Might), Dancing WebBoED, Extended Freedom of Movement, Greater Commandx4, Sacred GuardianBoED.
[6+1/day]6: (Extended Righteous Might), Antilife Shell, Healx3, Extended Righteous Mightx2.
[5+1/day]7: (Power Word Blind), Extended Exalted RaimentBoED, S(1d4 str), Fortunate Fatex4SC.
[7+1/day]8: (Power Word Stun), Consecrated Radiant Assaultx4, Extended Fortunate Fatex3, Lion's Roarx2SC.
[7+1/day]9: (Foresight), Consecrated Fire Stormx2, Mass Healx3, Miracle, Righteous Exilex2FC2.
[4+1/day]10: (Extended Storm of Vengeance), Celestial ValorHome, Cleansing RainHome, S(1d4 str), Mass Freedom of MovementHome, Summon Monster XHome
BoED - Book of Exalted Deeds.
FC2 - Fiendish Codex 2.
S - Sanctified spell. Sacrifice cost is noted in parentheses.
SC - Spell Compendium.
Hanna casts as an 13th level Champion of Gwynharwyf. The save DCs are 19 + spell level. Her spell theme is anything that helps while in a rage. Her metamagic options are Extend Spell (+1) and Consecrate Spell (+1)
[5/day]1: Divine Sacrificex5BoED
[4/day]2: Shield Otherx2, Warcryx2BoED
[4/day]3: Cure Moderate Woundsx4
[3/day]4: Break Enchantmentx2, Glory of the MartyrBoED.
[2/day]5: Cure Critical Woundsx2
Always active: Greater Mage Armor, Superior Resistance.
3/day-charm person, deep slumber. 1/day-burning hands, elemental swarm(fire only), fire seeds, fire shield, firestorm, flaming sphere, incendiary cloud, plane shift(fire only), produce flame, suggestion, wall of fire. Caster level 22nd. The save DCs are 19 + spell level.
Simmer casts as a 22nd level sorcerer. (Caster level 30th for lingering flames; caster level 28th for fire descriptor spells; caster level 23rd for other spells. +2 caster level bonus to overcome spell resistance.) Her spell DCs are 19 + spell level. (DC 20 + spell level for fire descriptor spells.) Her metamagic options are Searing Spell (+1), Fiery Spell (+1), Empower Spell (+1) and Maximize Spell (+2). All metamagic costs are reduced by 1 (minimum 1) for lingering flames. Simmer may 3 times per day apply maximize spell to any spell through her metamagic rod. Simmer heals a number of hit points equal to the spell level when she casts a spell with the fire descriptor. Simmer's spells with the fire descriptor set opponents ablaze, dealing 1d6 fire damage per round. Simmer may nine times per day declare a fire descriptor spell overwhelming, which renders a target dazed for one round if they fail the save. Simmer may seven times per day declare a spell that deals damage a battle spell, adding 3 points of damage per die of the spell. With her mystic fire gauntlets, 3 charges per day, swift action, add 2d6/3d6/4d6 bonus fire damage to a fire spell you cast.
[6/day]0: Acid Splash, Arcane Mark, Detect Magic, Detect Poison, Flare, Light, Mending, Prestidigitation, Touch of Fatigue.
[9/day]1: Blades of FireSC, Detect Secret DoorsFB, Lesser Orb of FireSC, Raging FlameSC, Ray of FlameSC, Shield.
[8/day]2: Boiling BloodCM, CombustSC. FireburstSC, GlitterdustFB, ScorchSC, Scorching Ray.
[8/day]3: Body BlazeSS, Fireball, Gaseous Form, Greater Mage ArmorSC, TonguesFB.
[8/day]4: Assay Spell ResistanceSC, Channeled PyroburstPHB2, Firestride ExhalationCM, Hallucinatory TerrainFB, Incendiary SurgeCM.
[8/day]5: Earth ReaverSC, Greater FireburstSC, Mage's Faithful Hound, Planar ToleranceSC, SeemingFB
[7/day]6: Fires of PuritySC, Lingering FlamesCM, MisleadFB, Superior Resistance.
[7/day]7: Delayed Blast Fireball, Greater Teleport, SequesterFB, Summon Monster 7.
[7/day]8: Greater Arcane FusionCM, Horrid Wilting, Irresistible DanceFB, Simmer's SurpriseHome
[7/day]9: Deadly SunstrokeCM, ForesightFB, Transmute Rock to LavaSC, Wish.
[4/day]10: Simmer's Contagious FireburstHome, True Meteor StormHome
CM - Complete Mage.
FB - Bonus spell from Fey Bloodline.
Home - Homebrew.
PHB2 - Player's Handbook 2.
SS - Sandstorm.
You should probably ask Moonlight, since she hasn't shared the location with the group. I'd assume she WOULD, but you wrote her.
Whoops.
Wind. The winds howl. You stand in a cavern so vast as to be endless, criss-crossed with narrow streams choked with ice. The winds blow against you, then to your side, then ahead. They are strong winds, constantly opposing you in varying directions. Only your magic keeps the howling at bay, Moonlight coming close and raising her voice to a shout, still barely heard, "WE'RE A BIT OUTSIDE OF VISUAL RANGE OF THE OUTER ELEMENTS OF THE DEMONS PINNING THEM IN! WE NEED TO GO AND SNEAK IN OR DEAL WITH THEM FROM BEHIND!"
Even then, her voice is only half audible, the winds tearing the sounds away.
Moonlight
HP: 414+14/414
Hanna
HP: 354/354
Simmer
HP: 333/333
CM - Complete Mage.
Home - Homebrew.
SS - Sandstorm.
[/quote]
'Let's use telepathy instead. I'll relay.' Tryll sends to the group, quiet yet clearly audible.
Calleigh holds up a wand, her mental voice just as energetic and chipper as her normal one, 'Silence, anyone!?'
"No," Simmer gives Calleigh a look, barely heard. Then in your minds, 'No. Verbal components.'
