Surraruthru growls at the pain, but tries to focus past it and cast a spell at the horrid thing attacking him.
Casting Habob, CL 25.
> roll 1d20+34 Concentration
> roll 1d100 Spell Failure
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 42 > [d20=8]
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 33 > [d100=33]
Surraruthru
HP: 257/296
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Displacing Stance: 3/7 rounds, 50% Spell Failure
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience, Energy Immunity (Fire)
You can't. Your will is fading, crumbling as you're held and beaten. The hands are relentless, without mercy.
> roll 1d100 51+ means pain
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 46 > [d100=46]
Fortune is with you. You endure just a little longer, flickering, twisting and avoiding the attacks. The bloated man again whips you once, aiming carefully and letting out a thundercrack of a strike.
> roll 4d4+17+1d6
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 32 > [d4=4,1,4,2][d6=4]
Fort save, Surraruthru.
> roll 1d20+29 Fort
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 43 > [d20=14]
The merest touch of that whip is agony. It cuts through your scales like a scythe, stinging the vulnerable flesh beneath them. You keep it together, clenching your teeth to stop from screaming.
Made the save. Go.
#619
Surraruthru goes back to struggling to get free.
> roll 1d20+26 CMB
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 39 > [d20=13]
Surraruthru
HP: 225/296
AC: 32+6
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Displacing Stance: 2/7 rounds, 50% Spell Failure
Relentless, grips like steel. The hands won't stop, won't let you go no matter what you do. You have to fight down a hint of panic as they rip at you again, seeking to tear you apart like a roast chicken.
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 88 > [d100=88]
> roll 5d6+18
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 36 > [d6=4,1,4,6,3]
It hurts! You keep your focus even as you're torn apart, as the bloated thing gestures upwards. Chains begin to come down from the ceiling, descending towards you.
Go.
Surraruthru struggles more.
> roll 1d20+26 CMB
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 29 > [d20=3]
Surraruthru
HP: 189/296
AC: 32+6
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Displacing Stance: 1/7 rounds, 50% Spell Failure
You struggle more, fail.
You feel a surge of panic as the chains come down, the hands trying to hold you in place for it.
> roll 1d100 51+ rolling this first to see if the chains need to grapple
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 73 > [d100=73]
> roll 1d20+30 vs CMD of 42
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 41 > [d20=11]
The only mercy is that you manage to avoid the chains as your stance ends. They're all around you, closing in. They don't have you - yet.
Go.
As his Displacing Stances fades away, Surraruthru calls upon his innate magic to help shield him from attacks!
Using Obscuring Mist. Not sure how racial powers figure CL for duration, but I'm guess it's Racial levels, so 8 minute duration if so.
Surraruthru
HP: 189/296
AC: 32+6
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), 50% Spell Failure
Roll 1d100 for spell failure on that, Iddy.
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 10 > [d100=10]
You can't.
Your body and soul are ragged, worn. You can't do a thing as the chains come down at you.
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 37 > [d20=7]
A surge of adrenaline hits you and you juke to the side, pulling off hands that only try and keep you still. The chains are dodged, the bloated nightmare completely focused on the chains, unmoving.
To the side, you see another vat appearing next to the last brain, rising up out of the ground. It's currently empty.
Go.
Surraruthru tries to launch an orb of force at the hands holding him, hoping to weaken their grip.
Orb of Force, CL 25
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 35 > [d20=1]
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 25 > [d100=25]
Surraruthru
HP: 189/296
AC: 32+6
Again, only failure. Your body refuses, your magic whimpers. You try all you can, as...
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 32 > [d20=2]
Again you dodge. The chains rattle as they try and loop around you, but you evade. As you do, you notice they have rotted, gummy bits of gray matter attached to them.
Go.
Surraruthru tries to fire a Disintegrate spell at the nearest brain in a jar.
Disintegrate, CL 25
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 54 > [d20=20]
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 1 > [d100=1]
Surraruthru
HP: 189/296
AC: 32+6
